How "NOT" to Husky
Re: How "NOT" to Husky
Not so bad then. A decoke and piston, new big end bearing and a bit of plastic metal for the crank case and you should be good to go. No worries. (thumbs)
- Has thanked: 419 times
- Been thanked: 158 times
Brilliant description!!!!pmsl.. That does look like the game is up for that engine, but you've had fun stripping it all and im sure have learnt a lot! and the rest of the bike still looks quite mint!!! :unsure:Dutchgit wrote:That's the reason I was asking if you'd take it apart out of interest Hu55ky.mikeyboy wrote:Quality :laugh: :laugh: :laugh: :laugh:
If there's parts coming out through the "walls" you can bet there's a big party going on inside.
Good luck with whatever you decide on it.
Stick a DR350 engine in it :whistle:
Then:
Now:
Now:
"Oh dear that is not good at all definitely need to source a s/h engine.
Have I missed how it actually happened or did you buy it like this?"
I bought it like this...
- Has thanked: 44 times
- Been thanked: 112 times
"They all sound like that Sir" . . . :whistle:
Good luck (thumbs)
Simon
Good luck (thumbs)
Simon
Hope you didn't pay too much for it...
You can part out the rest of the bike for reasonable money on Ebay or source a second hand engine.
Pretty sure you can chuck in a 450 / 510 engine as they are the same fitment, just a different barrel & piston.
The CafeHusky forum is a good source of knowledge, there's a good amount of following and racing going on in the USA.
HuskySport in Winchester (UK) are good for getting spares if you need anything.
Speak to Reece on the parts desk. He's very knowledgeable.
Good luck with whatever you decide to do.
Gav
Gav
Thanks Gav,f17th wrote:Hope you didn't pay too much for it...
Gav
I'd rather find a second hand engine than break it up for parts...
The damage has gone in to at least one of the valve seats so the heads shot :pinch:
...and some other parts aren't quite as straight as they once were :S
at least the rear shock is off and the swingarm so there's plenty to do... (thumbs)
I am saving up for a replacement engine!
Meanwhile... the forks and shock are being overhauled and the wheels and rear swingarm have new bearings.
There's a new sprocket/chain set coming.
And I need to figure out how a 2009 engine can fit the 2005 carb, I have been told that the rubber boot can be modified to make them fit?!
:huh:
:huh:
im guessing the 4th valve shim fell got into the oil or something, then got eaten, then the piston broke up at high RPM seizing the motor solid and sending the force down the conrod, through the crank and forwards to the balance shaft.... might have run without oil even?
ive seen some engines like this, but never that bad!
