Do Camelbak reservoirs have a 'shelf' life?
Mine has been sitting unused in a cupboard for 7 years and so far I've flushed it through a handful of times using 'Steradent' denture cleaning tablets (which apparently kill 99.9% of viruses) as that was all I could think of to buy to clean it.
It's a 2 litre reservoir and a Camelbak replacement is £50 which I'm loathe to spend...the rucksack its self is still A1...or maybe another cheaper reservoir would fit if this one shouldn't be used?
Cleaning an old Camelbak
- Scott_rider
- Has thanked: 29 times
- Been thanked: 294 times
- Has thanked: 803 times
- Been thanked: 534 times
Re: Cleaning an old Camelbak
I had the same problem, I took the bladder out turned it inside out and washed it in hot soapy water , then flushed and sterilised , the pipe wasn't easy to clean but got it done in the end ,
Replace the tube connecting and mouth part....then leave in freezer for hen not used ...kills everything and is fresh for next use ..mines over 10 years old just replaced tube once...there are other camelbak reservoirs ..worth the money...also they can be used in other backpacks..
I've a army camp for trails and a larger one for touring with storage use same 2 ltr reservoir and cap..
- Has thanked: 1404 times
- Been thanked: 652 times
I echo the replies above, had mine 10+ years and still going strong. I wash the bladder out, use a length of cord to push/pull through the tube and then soak the lot in Milton sterilizing tablets before use.
Once cleaned and dry, store it in the freezer to prevent the same issues. If you only use water and store it in that way it will last for years.
Yep, same here, I use a small amount of Milton liquid, flush it through several times then into the freezer. Flush it out again before use
Can't go wrong, as already mentioned above
- Has thanked: 1414 times
- Been thanked: 1669 times
My experience.
Use water only..flavoured/energy drink leaves residues that bacteria will love! I rinse mine out with a very weak diluted solution of household bleach prior to storage and then before use. Rinse throughly with fresh water before refilling. There might be a slight taste of swimming-pool, but it won't kill you. Water can also be put to other uses...ie refilling a radiator or washing a wound.
I'd beware of using a freezer as a means of sterilisation...freezing can kill some life forms (by rupturing cell membranes) but is also used to preserve others (frozen embryos as an example), that then return to life on thawing.
Others will obviously have different experience, this is just what works for me.
Camelbak do a very long thin bottlebrush for cleaning the tube.
- Has thanked: 287 times
- Been thanked: 132 times
We used to use chlorine tablets, dissolved in water, for cleaning bottling machines and water purification. Bromine will also work.
- Scott_rider
Thanks for the replies guys . I've tried to clean it about half-a-dozen times this week and it's still looking dirty which may or may not be just discolouration. Anyway, I've decided to err on the side of caution and bought a new reservoir from Amazon for £20. I don't think one of my last outings on the Berkshire Downs in 2015 has helped - I strayed off-piste and submerged myself and the bike in a farmer's slurry pit (which I thought was a big puddle) . God knows what went into the Camelbak tube... .
As said you can get a new bladder and hose from most decent camping shops (probably your easiest option)Scott_rider wrote: ↑Fri Jul 15, 2022 1:16 pm Thanks for the replies guys . I've tried to clean it about half-a-dozen times this week and it's still looking dirty which may or may not be just discolouration. Anyway, I've decided to err on the side of caution and bought a new reservoir from Amazon for £20. I don't think one of my last outings on the Berkshire Downs in 2015 has helped - I strayed off-piste and submerged myself and the bike in a farmer's slurry pit (which I thought was a big puddle) . God knows what went into the Camelbak tube... .
or
go to your local pub and ask the landlord for a small amount of their beer line cleaner basically it is a food safe bleach needs to be well flushed though,
once clean best idea is to rinse clean after every use and then store in your freezer until needed.
