guy martin
dave h
Has thanked: 321 times
Been thanked: 370 times
guy martin
Post by dave h »
guys garage,
new series just started channel 4
dave.
Nigel
Has thanked: 189 times
Been thanked: 102 times
Re: guy martin
Post by Nigel »
Loved it :D just read his latest book, I doubt he realises quite how special he is, he's just himself.
zimtim
Has thanked: 623 times
Been thanked: 548 times
Re: guy martin
Post by zimtim »
Thoroughly enjoayable
Yes Guy is a special kind person
Will tune in again next week
I see he has a project coming trying to bereak a landspeed record with an electric bike,
simonw
Has thanked: 71 times
Been thanked: 164 times
Re: guy martin
Post by simonw »
Worth watching this if you haven't seen it (and you're into engineering):
zimtim
Re: guy martin
Post by zimtim »
Three wheeled Piaggio racing tonight
Should be a laugh
If it's anything like this
Helicoptermanr22
Has thanked: 21 times
Been thanked: 131 times
Re: guy martin
Post by Helicoptermanr22 »
That looks awesome! Brilliant, thanks for posting
daveuprite
Has thanked: 2452 times
Been thanked: 3293 times
Re: guy martin
Post by daveuprite »
simonw wrote: Thu Nov 25, 2021 1:59 pm Worth watching this if you haven't seen it (and you're into engineering):
Love that clip. I really should have watched the whole program.
OK, so a question for the old school engineers on here. Can a CNC milling machine not exactly replicate the precision being achieved by this guy? Is that not why his craft is dying out?
Tonibe63
Has thanked: 1404 times
Been thanked: 652 times
Re: guy martin
Post by Tonibe63 »
A CNC lathe can achieve such tolerances (as long as the tool settings are accurate) but for a 1 off it's a lot of work with probably very little time saving over doing it manually.
If doing a batch you would probably generate the machining program from a 3D model using software but set the tools to leave a tiny bit of material on, that way you can measure the 1st off component and adjust the tool settings (using the machines control panel) until you get it spot on, then you can run a batch off. If you don't have the correct software you can manually write a program using 'G code' and again adjust the tooling on the 1st off before running off a batch.
vRSG60
Has thanked: 67 times
Been thanked: 84 times
Re: guy martin
Post by vRSG60 »
I lasted 30 minutes of episode 1. He’s not right in the head!
bill_qaz
Has thanked: 689 times
Been thanked: 898 times
Re: guy martin
Post by bill_qaz »
vRSG60 wrote: Wed Dec 01, 2021 8:31 pm I lasted 30 minutes of episode 1. He’s not right in the head!
And that is what makes him entertaining
Return to “THE PUB”
