For Sale Garmin Zumo 660 NOW SOLD !!
Hello Everyone I have for Sale my Garmin Zumo 660 it Comes with a Used Motorcycle Mount Complete with the Weather Cover , A Garmin Carry Case , A Garmin Usb Lead , A Garmin Wall Charger uk 3 Pin Plug , And a Usb Stick with the Owners Manual on it. This Model is NOT the Lifetime updates Model But it has the Latest Maps installed on it and an 8gb Micro sd card for extra Storage .The 660 Works Perfect and Has around 4 Marks on the Casing through use as Shown in the Photos.I am upgrading to the Zumo XT , I am Looking £100 for the Lot and will Pay the Postage . Cheers Francis
- DSC00185.JPG (50.13 KiB) Viewed 2616 times
- DSC00184.JPG (44.26 KiB) Viewed 2616 times
- DSC00183.JPG (54.71 KiB) Viewed 2616 times
Re: For Sale Garmin Zumo 660
Missed this Picture
- DSC00186.JPG (47.31 KiB) Viewed 2615 times
Hello ScottCC The inside Diameter on the Clamp i had is 12 mm , The Garmin Mount Bolts onto the Square Part of a Ram Mount and the Ball Part fits into the Swival Joint So that you can Adjust the Viewing Angle if Fitted on the Handlebars. On my Versys i had an above the Clocks Mount with a Round bar, A Square Bracket Bolted to the Back of the Garmin Mount which then was Held on the Bar with a U shaped Clamp. In the two pictures is the Bracket that Clamps onto the Round Bar , I dont Know were i got it but Only two out of the Four Holes on the Bracket line up with the Holes on the Garmin Mount , I used the Bottom two holes to bolt it to the Garmin Mount and used two of the Tiny Cable ties on the top two holes with No Problems for Several Years .I hope this Helps Cheers Francis
- DSC00188.jpg (51.59 KiB) Viewed 2511 times
- DSC00187.jpg (64.45 KiB) Viewed 2511 times
Hello Again Jasext Nothing in the inbox , I Will keep an eye out for a New Message , Thanks for the info. Cheers Francis
