Waterproof tail pack?
DavidS
Has thanked: 753 times
Been thanked: 349 times
Post by DavidS » Fri Dec 01, 2017 10:49 am
I have the little Rally Raid rack on my KTM 690 Enduro, which, to be honest, doesn't have the largest capacity and certainly is no use for my now redundant Kriega US20 (that I used to use on my old 950SM).
I am thinking of getting a small WATERPROOF tailpack that will easily strap onto the rack that will take my little folding emergency rucksack (the size of a large wallet when folded) , some bungees and maybe other small odds and sods. Only for local riding - no adventuring.
The Kriega US5 is a bit floppy and not a great fit so i was thinking more of a shaped pack.
Inevitably, the question is.....any suggestions?
For my current riding, there is no point in spending silly money but I do want it properly waterproof rather than just wrapping everything in plastic bag.
2019 Triumph T120 Black
LOOKING FOR A USED 2019/20 KTM 690 ENDURO R
zimtim
Has thanked: 576 times
Been thanked: 502 times
Re: Waterproof tail pack?
Post by zimtim » Fri Dec 01, 2017 11:26 am
Kriega us 10 :D ?
DavidS
Post by DavidS » Fri Dec 01, 2017 12:20 pm
Thanks, but the 5 is already a tad too long so hoping to find a small shaped or rigid-ish pack.
I only need it for the odds and sods mentioned above and some thin emergency waterproofs that I had forgotten to include.
I have found some on tinternet but I would be buying blind so user advice always welcomed.
herman
Has thanked: 878 times
Been thanked: 631 times
Post by herman » Fri Dec 01, 2017 10:09 pm
Probably a small roll top dry bag under a cargo net would be the simple answer. I use an Alpkit one for day trips but the waterproofs go on the outside under the net. Would a bar bag do it? don't fancy them myself as I don't even like bar pads but each to their own.
~ACP~
Has thanked: 131 times
Been thanked: 67 times
Post by ~ACP~ » Fri Dec 01, 2017 10:53 pm
Any good?
https://m.ebay.co.uk/itm/Enduristan-Ral ... SwJQdXDRI1
Take a look at other Enduristan stuff. They've got some good waterproof gear.
cowling
Has thanked: 17 times
Been thanked: 33 times
Post by cowling » Sat Dec 02, 2017 7:29 am
As already mentioned, I use roll top dry bags,
Lomo ones are great value, not very strap on friendly, and if you want owt the bag generally has to come off and the full contents out, but once you get the knack, you can do this very quickly, they are the cheapest option, some of the dedicated tail packs are a fortune. I'd be interested in your kreiger if you sell it on.
boboneleg
Has thanked: 1722 times
Been thanked: 981 times
Post by boboneleg » Sat Dec 02, 2017 8:08 am
Tim beat me to it......... US10
one-legged adventurer
zimtim
Post by zimtim » Sat Dec 02, 2017 9:31 am
What about something like this
search-results/product/MAX235H105/4-ltr-ip67-rated-waterproof-protective-grip-case-%7c-solent-plastics
Would be a more permanent fixture, but quite a few on here use Tramp, PIF
Bolt it directly onto your rack then seal all holes with a silicone sealant when I had mine it never leaked.
DavidS
Post by DavidS » Sat Dec 02, 2017 11:53 am
Thanks for your suggestions guys. Working through them lead me to this Kriega https://kriega.com/works-series/rally-pack that I didn't know existed.
I can refit the grab rails and flog the rack as it bolts on to the fender and also discuss terms with Cowling on the US20. :D
Jackoblara
Post by Jackoblara » Sat Mar 02, 2019 8:48 am
I am thinking of getting a small WATERPROOF nylon tailpack that will easily strap onto the rack that will take my little folding emergency rucksack (the size of a large wallet when folded) , some bungees and maybe other small odds and sods. Only for local riding - no adventuring.
need these waterproofs
Return to “TRAVEL GEAR”
Users browsing this forum: No registered users and 30 guests
