I've searched everywhere for some off road tyres to fit the Honda CG125
These are the sizes:
Front tyre size 2.75 x 18
Rear tyre size 90/90 x 18
Any ideas of where I might get some much appreciated.
CG125 off road tyres
- Has thanked: 2280 times
Re: CG125 off road tyres
should be loads of places .. m and p, oponeo, do a search on internet?
but i heard of a guy riding up soar y mynedd hill with a cg125 .. sounded like a good idea to me too,
but he knocked his sump on the many rocks, on the way up .. i think he knackered the bike?
so ground clearance would have to be looked at? and altered?
- Has thanked: 7 times
- Been thanked: 1 time
Thanks for the reply. Tried both those and half a dozen others. Let me know if you can see anything.
Bridgestone battlax rear .. AX41 .. 100/90 x18
https://www.oponeo.co.uk/moto-tyre-find ... om3OrFRGk=
Thanks for that. Different dimensions, so not sure if it would fit. I'm not very well up on tyre sizes.garyboy wrote: ↑Sat Feb 06, 2021 12:39 am Bridgestone battlax rear .. AX41 .. 100/90 x18
i have used oversize tyres.. by 10 mm .. but i am not an expert by any means .. just trying to help ... best to see an expert.
edit .. actually, 2.75 inches is about 70mm
so it would probably be too wide for the front at 100mm
but may be ok for the rear? .. just be wider and lower? .. although classed as `front` ??
best to check
best to check
C353 cats paw fit in a slightly larger size . look at the wheel rim for the size that is stamped in, then google that and it it will tell you what size tyres will fit that rim.
Here they are fitted to the Cg125 scrambler I built .
viewtopic.php?f=23&t=21863
