Top box turned into a catchtank.
bikenav
Has thanked: 776 times
Been thanked: 452 times
Post by bikenav » Mon Dec 21, 2020 2:05 pm
I have a plastic Givi topbox a big one not the budget one, had it a good few years bought used from the original carefull buyer. It has suddenly started to let in water, although it has been dropped on a couple of occasions whilst mounted there is no visible damage other than minor stuff to the trim. The seal, lips, mating surfaces, hinge, latch and all the main body appear perfectly servicable, there are no mods, cracks or holes drilled in it. Its a real puzzle to me where the water is getting in, parked overnight on the sidestand it will collect a cupfull of rain. Anyone come across this and found the leak point and or a solution. Ta very much.
Has thanked: 816 times
Been thanked: 1066 times
Re: Top box turned into a catchtank.
Post by Richard Simpson Mark II » Mon Dec 21, 2020 3:33 pm
Fill with water, close lid, invert, observe leak
OnHellas
Has thanked: 434 times
Been thanked: 824 times
Post by OnHellas » Mon Dec 21, 2020 3:58 pm
Don’t leave top box on the bike when it’s raining.....
....sorry, I’ll get my coat.
fatowl
Been thanked: 39 times
Post by fatowl » Mon Dec 21, 2020 4:12 pm
Sprinkle talcum powder or similar around the top lip inside, then see where it gets washed away.
bikenav
Post by bikenav » Tue Dec 22, 2020 5:31 pm
thanks for the thoughts, this is the second box gone the same way, they do have a bit of a rough time with me I suppose but more than a little frustrating, I think the talc powder may be my first try, sounds promising that leaving a witness, they only way I can imagine is water running around the vertical lip then backing up at a pinch point then pushing up and through the seal. perhaps cumlative wear on hinge, latch not creating enough pressure down on the seal, so may pick out the seal and put some packing under it, or it could all be misshaped but it closes sweetly.
dibbs
Has thanked: 371 times
Been thanked: 123 times
Post by dibbs » Tue Dec 22, 2020 8:41 pm
:lol: :lol: :lol: clever! I like this idea.....thinking outside the box!!!!! See what i did there lol....
dazcoates
Has thanked: 126 times
Been thanked: 14 times
Post by dazcoates » Sun Jan 03, 2021 6:52 pm
If you cant find the leek could you drill a hole where the water collects so at least it could drain out ?
Has thanked: 591 times
Been thanked: 516 times
Post by zimtim » Sun Jan 03, 2021 7:02 pm
You could use a silicon sealant around the seals, the hinges and lock then close it.
You might not be able to ever use the box again but at least it won't leak :geek:
Return to “ACCESSORIES”
Users browsing this forum: No registered users and 84 guests
