Sheepskin covers
Vincent Velocette
Has thanked: 3 times
Been thanked: 6 times
Sheepskin covers
Post by Vincent Velocette » Tue Feb 18, 2020 1:36 pm
How do you attach yours to your seat?
The last time I used my bike I stood up to stretch my legs and forgot it was only my weight that was securing mine.
A quick stop and turn having to explain it wasn't a Persian cat I was recovering it was my seatpad left following motorists bemused. :D
lancashirelad
Has thanked: 116 times
Been thanked: 134 times
Re: Sheepskin covers
Post by lancashirelad » Tue Feb 18, 2020 3:07 pm
2 elastic straps round the seat.
KLX250 presently concentrating on not spending money on farkles and summoning up the courage to throw it at the scenery.
Mickdb1
Been thanked: 50 times
Post by Mickdb1 » Tue Feb 18, 2020 3:50 pm
One elastic strap around seat with the "top of the seat bit" having a 50mm strip of velcro soft side sewn on - Sheepy has the hook velcro sewn to underside. Rip it off to shake water off or use it as a pillow stuffing.
HTHY
Billy Bananahead
Has thanked: 71 times
Been thanked: 145 times
Post by Billy Bananahead » Tue Feb 18, 2020 4:21 pm
Laid lengthways over seat, fur side down, bungeed over and then folded back to show fur side up.
zimtim
Has thanked: 573 times
Been thanked: 499 times
Post by zimtim » Tue Feb 18, 2020 4:22 pm
Mine was attached using four eyelets per side and two long bootlaces.
Also had some of the rubber anti slip glued to the underside.
I took it off, and the dog decided it looked better and was put to much better use in her bed.
I must get another one
Mickdb1
Post by Mickdb1 » Tue Feb 18, 2020 7:42 pm
I put the Velcro on after visiting my mate Jaber from ambergate. He had his sheepy on his Royal Enfield permanently. His cat took a fancy to it and laid a large "egg" on it. !!!!!!!!!
Chalky723
Has thanked: 23 times
Been thanked: 14 times
Post by Chalky723 » Wed Feb 19, 2020 8:47 am
I sewed a strap on in the middle, with a buckle clip, that does up under the seat, I left "wings" on the front of the skin when I cut it, so they tuck under the front of the seat (with a bit of pushing)...
D
Vincent Velocette
Post by Vincent Velocette » Wed Feb 19, 2020 10:02 am
Cheers for the replies folks.
Does anybody have any pictures. I'm a see it and understand kind of bloke.
gbags
Has thanked: 595 times
Been thanked: 344 times
Post by gbags » Wed Feb 19, 2020 12:27 pm
How tough is the leather?
I want something with plenty of eye holes that I can tie in tight and then forget about.
zimtim
Post by zimtim » Wed Feb 19, 2020 2:16 pm
The leather isn't that tough, the issue is the fleece itself.
I did find that tying it too tight eventually tore the leather, if I were to use the eyelets and bootlace again I would reinforce the area where they go with either a stronger thicker piece of leather or maybe some off cut from a tube or webbing
Return to “ACCESSORIES”
Users browsing this forum: No registered users and 80 guests
