Noob Bar Riser Query
Cone
Has thanked: 156 times
Been thanked: 250 times
Post by Cone » Mon Apr 10, 2017 7:49 pm
So a bit of a nooby question here so i apologise first.
How do I know whether I need bar risers? I ride a lot offroad find my self bent at the knees and crouching a little forward, is this the right position? I'm not massively tall but the f800 is still quite a big bike!
I have seen lots of different kinds, I'm tempted for the cheap Chinese kit on ebay, but i do fall off every now and then and the big heavy beemer goes with a bang, would these hold up in a off, anyone have experience?
Before you say it, yes i know i should invest in a few days training but i'm learning the hard way! :woohoo:
I do intend to do it but finding time with two small kids and a bit of spare cash for a training day is hard! I wish the bloody missus would get a job! :blush:
Mike54
Has thanked: 18 times
Been thanked: 95 times
Re: Noob Bar Riser Query
Post by Mike54 » Mon Apr 10, 2017 7:57 pm
Legs should be not locked but should be straight most of the time.
Go on a proper training course before you start buying things. David Knight at 6'4 doesn't use risers, in fact he uses a low bend of bar.
zimtim
Has thanked: 573 times
Been thanked: 499 times
Post by zimtim » Mon Apr 10, 2017 7:58 pm
Watch this video I think he knows a thing or two about body position, Before you go buying bar risers, try rolling your handle bars either back or forward through the bar clamps.
knobblyneil
Post by knobblyneil » Mon Apr 10, 2017 11:18 pm
Hi Cone
I`m 6`4 and had an 800 for 5 years which was 60% ridden off road, I convinced myself because I was tall i needed them, I found the longer bolts bent easily if i dropped it so got rid of them. On a course with guidance I found legs straight and the right body positioning did away for the need for them. I have`nt fitted them since just move around the bike more.
Neil
johnnyboxer
Has thanked: 71 times
Been thanked: 277 times
Post by johnnyboxer » Tue Apr 11, 2017 6:47 am
Mike54 wrote:Legs should be not locked but should be straight most of the time.
Good advice
I usually fit a higher bend of bars instead of risers
Risers - I feel they add a kind of vagueness to the steering and longer bolts can bend in a fall
Cone
Post by Cone » Tue Apr 11, 2017 7:26 am
knobblyneil wrote:Hi Cone
Neil
Thanks that's good to know, I do intend to do a course one day! Just a question of when, i'm buying a new house at the moment so guess its struck of the list for a while!
Cone
Post by Cone » Wed Jul 19, 2017 6:35 pm
Decided I need a set of risers. How much can I extend on the standard cabling and hoses?
Mike101
Post by Mike101 » Wed Jul 19, 2017 8:22 pm
I'm 6ft tall but with only a 29 inside leg. This means I have a very long body. I need bar risers or my neck hurts when I stand up.
I used Rox risers on my 950..expensive but good. There are plenty of 20mm risers on eBay that are cheap to try and see if it helps.
MIKE
Cone
Post by Cone » Wed Jul 19, 2017 9:06 pm
Yes but I don't want to be replacing hoses. I was looking for a bit of advice from others with f800s who have bar risers fitted whether they needed to fiddle or just pnp
anthony29040
Has thanked: 5 times
Been thanked: 54 times
Post by anthony29040 » Thu Jul 20, 2017 6:43 am
Cone wrote:Yes but I don't want to be replacing hoses. I was looking for a bit of advice from others with f800s who have bar risers fitted whether they needed to fiddle or just pnp
I fitted rox riser copys to my gs 800 and took them of no matter how I routed the hoses and cables they where to tight on lock to lock.they are a 50mm rise.you might get away with a 25 or 30 rise and also mine is a 2009 model might be longer hoses on yours ?
hope this helps tony.
Return to “ACCESSORIES”
Users browsing this forum: No registered users and 102 guests
