- 4512964x800x0_FFFFFF_E.jpg (36.54 KiB) Viewed 1487 times
XSR900
- mark vb
- Has thanked: 329 times
- Been thanked: 695 times
XSR900
I really like the look of the revamped XSR900, looks straight out of the 80's Deltabox era. I've heard good reports of the MT09/Tracer engine and handling, so the XSR will I suspect be a cracker. And that classic blue/yellow paint.... Looks just like a proper roadster should I can see it relishing in a good thrashing around the Alps, something I haven't done for a while.
- Has thanked: 21 times
- Been thanked: 131 times
- Has thanked: 2452 times
- Been thanked: 3293 times
Re: XSR900
As you say, Mark, it's very deltabox isn't it? Looks like an FZR1000Exup that's been crashed and streetfightered.
Re: XSR900
Nice colour scheme and plenty of grunt available but probably still a bit heavy due to cost constraints. I have the XSR700 and to be honest it's surprisingly quick up to the ton at which point I struggle to hang on, suspension is the weak point on the 700, in my opinion, not sure if the 900 is better on the worsening road surfaces in the UK.
- Scott_rider
- Has thanked: 29 times
- Been thanked: 294 times
Re: XSR900
...I've got the Tracer 900 (mark 2) which has a stonking engine and the same one as in the XSR900. The general consensus is that they are set up at the factory for a 'light' rider and a bit of tweaking helps the suspension a lot. I firmed up the front end on mine and it made a huge difference. The engine for the new models has been enlarged from 847cc to 890cc...so should be even more stonking .onslowe wrote: ↑Fri Nov 12, 2021 8:49 am Nice colour scheme and plenty of grunt available but probably still a bit heavy due to cost constraints. I have the XSR700 and to be honest it's surprisingly quick up to the ton at which point I struggle to hang on, suspension is the weak point on the 700, in my opinion, not sure if the 900 is better on the worsening road surfaces in the UK.
