AJP PR7 Owners?
- Has thanked: 1404 times
- Been thanked: 652 times
Re: AJP PR7 Owners?
I've heard that lithium batteries need a specific charger/conditioner, maybe someone with better knowledge than me could confirm??
- OB1
- Has thanked: 746 times
- Been thanked: 342 times
Re: AJP PR7 Owners?
They do... I checked the internet and thought that I had the right Optimate... but I didn't. It was a costly lesson.
justrtw.com
justrtw.com
- Has thanked: 70 times
- Been thanked: 178 times
Re: AJP PR7 Owners?
OB1 - re the lithium battery, mine holds charge far better than the Lead/Acid equivalent, however sometimes it feels lethargic...
The solution is to turn on the ignition (headlight comes on)and leave for 30 seconds before attempting to start, apparently this "wakes" the lithium battery up. Works every time on my PR7, even after a night left out in frosty Wales.
(This works for all Lithium batteries I'm told).
- OB1
Re: AJP PR7 Owners?
Crossrutted wrote: ↑Mon Jun 28, 2021 3:09 pm OB1 - re the lithium battery, mine holds charge far better than the Lead/Acid equivalent, however sometimes it feels lethargic...
I read that exact same tip on ADVRider this morning!
The new battery has arrived and has been fitted: all systems are go.
justrtw.com
justrtw.com
- Has thanked: 1414 times
- Been thanked: 1669 times
- OB1
Re: AJP PR7 Owners?
Richard Simpson Mark II wrote: ↑Mon Jun 28, 2021 4:05 pm Can't wait to hear some feedback on the bike
I'm heading up to Donnington for the World Superbikes at the weekend (a Christmas present from my sister) and I've taken the following week off so that I can do a little touring on the bike. I was thinking of nipping up to Kirkby Stephen to visit the importer/main dealer to enquire about the Power-up Kit.
justrtw.com
justrtw.com
Re: AJP PR7 Owners?
Good one! Don't for get to take in some lanes...there are some around Coalville, Leics, I think.
- Has thanked: 95 times
- Been thanked: 448 times
Re: AJP PR7 Owners?
I to have been reading the blurb on specific LiFe batteries. They say that damage can occur if the charger is left on too long and the charger enters the "float" stage automatically. However, I still question the situation quite simply because the bike's charging system doesn't know what battery type is fitted and will simply maintain supply voltage to a bit over 14V. I have charged Li batteries using a decent charger designed for AGM and it didn't go into desulphate mode because of the higher battery terminal voltage. I think the key is to hold the supply voltage to a little over 14V and not to leave it on for too long--but I'm no expert.
Re: AJP PR7 Owners?
There is indeed Richard but they are boring and flat so if OB1 is heading up to Kirby Stephen from Donnington then personally I would search out much better lanes going up through the Peak District and Yorkshire Dales.Richard Simpson Mark II wrote: ↑Mon Jun 28, 2021 4:30 pm Good one! Don't for get to take in some lanes...there are some around Coalville, Leics, I think.
- OB1
Re: AJP PR7 Owners?
catcitrus wrote: ↑Mon Jun 28, 2021 6:10 pm I to have been reading the blurb on specific LiFe batteries. They say that damage can occur if the charger is left on too long and the charger enters the "float" stage automatically. However, I still question the situation quite simply because the bike's charging system doesn't know what battery type is fitted and will simply maintain supply voltage to a bit over 14V. I have charged Li batteries using a decent charger designed for AGM and it didn't go into desulphate mode because of the higher battery terminal voltage. I think the key is to hold the supply voltage to a little over 14V and not to leave it on for too long--but I'm no expert.
If you feel like creating some carbon fibre goodies for the PR7, you can use mine as a testbed as I'm just down the road!
justrtw.com
justrtw.com
