prg4967 wrote: ↑Sat May 09, 2020 9:27 am
You’ll want a basic tool kit, spare levers, handguards will save your levers but carry a clutch lever at least, the KTM stock plastic bash plate is fine unless your doing a lot of rocky stuff, Spare tubes is a must unless running mousses and know how to change a tube..but the best mod if your into spending a bit of money is get the suspension set up for your weight (in riding gear) ... and the spend the rest of the money you have on petrol !
Are the Motion Pro compact tool kits worth it ? They do look well thought out.
I'm sold on the lever - I bent my front brake lever downwards rolling my big gs upside down. I'd rather have both so I can get down a hill safely if I break one ! I dont like getting stranded !
Good to have an opinion on the std bash plate - I've got a thicker alloy one on my big gs, but they are a touch heavier of course. I did a bit of rock stuff when I was younger and would rather not go mad now
They hurt a lot more when you get it wrong and youre old.
Simon P spits at metal bash plates on enduros - but why is plastic better ?
I forgot about tubes - is carrying 1 big enough for the front actually ok ? (Years of experience with puncture kits and tyre levers
) What are the best tyre levers ? Motion Pro with a ring end look nice, but they are not cheap !
I'll be on the bottom of the scale for the std suspension, and I've read that they are softish as std (heavy testers ?) so I'm hoping that it'll be fine once I click it about a bit. (Years of playing with full-sus mtbs)
