WK400 owners thread.
EdwardCollings
Has thanked: 6 times
Been thanked: 3 times
Re: WK400 owners thread.
Post by EdwardCollings » Mon Aug 10, 2020 7:36 pm
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 7:40 pm
Started commuting to work on my bike to find I think 3 issues
Tank forming a vacuum
TPS not dialed in as I thought
Tick over a little low
I experienced cutting out on a low tank under certain conditions that as soon as I brimmed my tank went away
I removed the brass cup and ball bearing and then opened up the small hole. I have actually further opened up the fuel cap after looking at an Aprillia forum and I'm happy to say it's sorted that problem
I'll get some more photos when some fuel tank baffle arrives I was going to place in the opened up hole to stop fuel on a very full tank coming up the hole so easily .
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 7:42 pm
I've found all the screws to be JIS not Philips
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 7:48 pm
Whilst trying to fiddle with the idle screw the aluminium throttle body had oxidised around the screw. I eventually got it out and have since replaced it with an M5 25mm grub screw as it makes adjusting it with an Allen key and locking it in position with an 8mm locking nut
I have found winding the screw all the way out, setting the TPS to .78 and fettling with the adjustment screw has sorted the cutting out issue.
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 7:56 pm
I've also doubled up on the oil coolers by taking off the mounting plates and using M6 X 160 bolts and bolting the two together
I've fitted an oil temperature guage I'll get a photo of tomorrow so I can see if I'm now over cooling the oil
Andi asked if the could get trapped air and if I'm honest I don't know. I check with my hand the heat feels evenly spread but as they're so small it would be hard to tell.
As the system is a dry sump I found by chance when I changed a fitting the bottom radiator drains back to the engine once the engine is off so it drains and refills everytime you start and stop the engine.
Just wish I knew what the oil temps were before the oil coolers were fitted and where the guage is fitted in place of the dispstick it reads the cooled oil not the oil coming out of the engine
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 7:58 pm
Fitted a 4mm spacer so I can now tighten down the seat front bolt without pulling so much into the fabric of the seat
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 8:01 pm
That's nipped up tight
EdwardCollings
Post by EdwardCollings » Mon Aug 10, 2020 10:30 pm
https://www.ebay.co.uk/itm/283546357160
This is the oil guage that fits
Scotriders
Been thanked: 12 times
Post by Scotriders » Mon Aug 10, 2020 10:54 pm
EdwardCollings wrote:Hello Ned
Is the engine getting too hot and cutting itself out? Reason I ask is I've noticed since tuning the bike as we have spirited dual carriage way riding gets the bike pretty hot.
I think it is getting hot but don't think that's the reason it's cutting out as it starts again as soon as I switch the ignition off and on again.
It feels like it's a rev limiter kinda thing.
Sent from my FIG-LX1 using Tapatalk
Andi_Archer
Been thanked: 126 times
Post by Andi_Archer » Tue Aug 11, 2020 1:17 am
The standard one is a tad fast I’m surprised an mot station hasn’t mentioned it yet.
Users browsing this forum: bill_qaz, Bing [Bot], daveuprite, Elmer J Fudd, garyboy, Godspeed, Google [Bot], Richard Simpson Mark II, Tiger7, Toe and 227 guests
