im not a great mechanic but im not usless either ..i maintain and service all my own bikes ..
i put the bike in for a petrol pipe leak earlier in the yrear
....it had all new tanks as they were the early ones and had not been changed .. re routed improved brathers ...they found a hairline crack on the header pipe and just replaced it unexpected no known about ..no questions no quibble no charge ..and i just thought thought i was gettina two quid pipe fitted ...
they lent me a bike and chris ..cad engineer rode my bike to m wigan workplace and swopped back to the loan bike
...that is not shabby by any standard .. i know im lucky living thirty miles from the factory but ...again that is service ..is it not ??
with the new gearbox my warranty is void on the engine i dont let it worry me the bike runs fine
on a positive note ccm have been pretty good with support checking the valves is to be honest a very easy task once you have got to them :sick:
its no different to any other overhead cam motor .they were comfortably in tolerance at 5000 miles ... miles inside
should they need re shimming later its a very straight forward procedure
owners are provided with a 250 page full workshop manual which you can store on your smartphone ..the crank locks from a pin hole via the sump foollw the crystal clear maual to remove ..intall shims and reverse ...thats it its not difficult ..just the same as any modern cylinder head ..if you dont fancy it any mechanic will be able to do them for you..just give him the manual on the flashdrive
..the rest of the stuff is bog standard and easy
just as a for instance ... i had a blown fork seal after bulgaria ..the stupid feckin courier idiot that picked up the bike from the depot after it was brought back cranked the front down with rachet straps with no block and blew it
id not done marzochie stuff before ..quick phone call to ccm ..a quick chat later i got the seals ..also got a full workshop manual for the forks pinged over to me same day ..was put through to paul the chief mechanic who told me i could slide hammer the forks apart without removing the cartarige ..good to know happy days ..and the seals arrived next day (thumbs)
off the bike to back on in around 45 mins job done
my point is here that i cant think of any factory that would give you this kind of support and help ..they will help you to maintain your own bike and getting to know your own bike this way is a good thing ..its a hybrid a type of dirt bike and we cant expect to be nannyd and things to be ok for 5000 miles of dirt type riding without hickup
i think like most adv bikes you need to get hands on ..if that suits your style you will get more help from ccm than any dealer i reackon..imagine ringing up a ktm dealer and get that kind of help and responce ..workshop manual parts and head mechanic all in one call B)
so this kind of relationship suits me as i feel i know my bike pretty well now
