- Has thanked: 201 times
- Been thanked: 272 times
Fitted a Givi E251 plate to the Precision Made Rack that came with the KLX250 I bought, PMR asked for details of the fit so I’ve sent pics to them, I still haven’t ridden the bike though but at least I can store my helmet when I do!!
The plate was a bargain £25 new in box usually £40+
Last edited by lancashirelad on Mon Feb 15, 2021 12:15 am, edited 1 time in total.
I’ve also fitted one IMS footrest, one to go, no good rushing these things
- Has thanked: 8 times
- Been thanked: 56 times
Adjusted the chain on the V Strom, recently removed the lowering rear link's & put it back to standard hight.
Now waiting for a rear hugger to be delivered .
Ian.
Ian.
- IMG_20201102_151432.jpg (168.95 KiB) Viewed 1225 times
- Has thanked: 1187 times
- Been thanked: 760 times
not a good week for my old lady, my throttle cable been a bit stiff for ages, baulked at buying a new set, BMW price for a set of cables is bonkers could not get a custom set made as they needed the original, not practical for me. made up a new inner from bicycle gear cable a little smaller diameter at 1.1mm and hand made nipples thought I would get away with it, even though they turned out well the outers were toast, nah. Was not happy with butterfly spindle bearings in the throttle body so one of them I had lying about and a set of used cables sorted that. 2 days later I could feel the high tension breaking down on acceleration so guessed it at a coil stick (not the first) a full used set of four came in the post they were a good price never have changed the secondary ones so just in case 50/50 which one, second go another primary one it was as I expected really. Indicator switch gave up working for I think the third time for this particular switch and it has probably been replaced before lost count to be honest but whose counting huh. Pulled this one to bits at least twice before but once the green death starts on the miniscule contacts the future aint going to be orange for long little bastards they are IMO they dont belong out in the weather on a Moto. Got some spare micro switches so may be cutting and soldering tomorow or just the spare cluster may go on, I hate soldering probably as I am crap at it, got a new iron to try but I dont think its the iron that is the weak point . I am not holding any grudges at the old lady but perhaps she needs a younger sister to help with the the heavy lifting.
- Has thanked: 1404 times
- Been thanked: 652 times
Younger models are always waaay more expensive and atleast you know where the 'microswitch' is on the current one .
I fitted a 13T front sprocket to the KLX250 & a Gold DID chain, all was going well till I lost the spring clip for the chain I gave up after 20 mins then the wife found it in 2 mins, I also fitted the r/h IMS footrest
Rode my Tracer 900 gt to Mototechniks for them to replace front brake light/cc switch for Yamaha recall, 1.5 hr round trip, 1st this year off for Covid jab next Saturday, 1 hour round trip so a grand total of 2.5 hrs riding this year, woo hoo!
- Has thanked: 116 times
- Been thanked: 268 times
New front tyre the right size for the bike, 100/80-17, and a different petrol tank.
Spring service completed:
Front brake cyclinder serviced
Suspension linkages greased
Oil change
Air filter cleaned
Now I just want to get out and ride it!!!!
New front and rear padsFront brake cyclinder serviced
Oil change
Air filter cleaned
Finished servicing my Tiger 800xc.
Items include pumped right out front caliper pistons and cleaned up and bled system, cleaned air filter, cleaned drive chain, replaced dodgy Triumph throttle body clamp screws with Yamaha items and main item of concern was to replace the dodgy stepper motor idle mechanism (although it still has to be wired in) with a manual adjuster for a Daytona 675. We shall see about that. Not forgetting the oil and filter change, coolant top up and original bash plate instead of the Heed affair.
