R1200GS EWS! Issue - Help! 😫
Ben750
Post by Ben750 »
Hi guys,
Wonder if you can help.
I’ve a friends 1200 GS in my garage, rendered immobile.
He was riding along and it just died. Lost gear indicator / neutral light etc too.
Traced a number of breaks in wiring, all repaired. And diagnosed a dead ECU.
Fitted a known good ECU and the neutral light is back, gear indicator etc. however the brake failure light remains constant which was there before too - however this shouldn’t stop it starting?
Bike won’t turn over on the button and dash is as the below pic! Any ideas?
Cheers!!
Edit: also tried a new ring antenna.
Husky FE350 Rockstar Edition
KTM EXC250 Six Days
Ducati ST2 race bike
Billy Bananahead
Has thanked: 116 times
Been thanked: 270 times
Re: R1200GS EWS! Issue - Help! 😫
Post by Billy Bananahead »
Battery past it's best?
Tonibe63
Has thanked: 1404 times
Been thanked: 652 times
Post by Tonibe63 »
My first port of call would be UKGSer forum and use the search facility.
Scott_rider
Has thanked: 29 times
Been thanked: 294 times
Post by Scott_rider »
It might be a long shot but it might be worth checking the earth from the battery to wherever it’s fixed on the frame? My old KTM 400exc died one day due to the earth coming loose on the frame. I also had a Speed Triple 1050 that would start and run like a dog with various things not working which turned out to be just a duff battery.
bikenav
Has thanked: 1187 times
Been thanked: 761 times
Post by bikenav »
maybe a help you could possibly jump the starter solenoid direct to see if it will run once spun up not a fix I know, just run a live down to the spade connector on the solenoid. both my GS's have a wire going down there so I know I can at least spin it over without talking to the ignition /canbus etc in the event of an issue. Would be interested in any conclusions ta.
DanielS
Has thanked: 36 times
Been thanked: 149 times
Post by DanielS »
I had this on my 2006 1200GS too occasionally (EWS Error). Often putting the key in the other way around helped. But in my case it was the antenna around the key. Good info here:
https://www.ukgser.com/forums/showthrea ... WS-warning
