USB handlebar charging
daveuprite
Has thanked: 2452 times
Been thanked: 3293 times
Post by daveuprite »
I want to fit some kind of handlebar mounted charger, connected to the battery, which I can charge my phone from via USB.
Looking at this thing:
https://www.ebay.co.uk/itm/164375575470 ... SwnyFfBr8-
Any advice / ideas / preferences?
Snaf MKII
Has thanked: 920 times
Been thanked: 752 times
Re: USB handlebar charging
Post by Snaf MKII »
We've got these fitted to all our KTM's and BMW's as well the works vans. Never had any trouble with them even after having to dig mud out of one.
https://www.ebay.co.uk/itm/384107916000 ... SwhXZgf5uO
chipy
Has thanked: 33 times
Been thanked: 111 times
Post by chipy »
Make sure you wire it via relay or the transformer will flatten the battery on your bike.
daveuprite
chipy wrote: Fri Nov 26, 2021 5:55 pm Make sure you wire it via relay or the transformer will flatten the battery on your bike.
Yes I'm interested in NOT doing exactly that, Chipy. Wouldn't the on/off switch sort that out?
Snaf MKII
Post by Snaf MKII »
On our KTM's I've taken a feed from the lighting circuit, this circuit turns on and off with the engine.
The BMW's I use the accessories feed which comes on with the key.
fatowl
Been thanked: 64 times
Post by fatowl »
It might, until you forget to turn it off.
Hugh
Has thanked: 878 times
Been thanked: 929 times
Post by Hugh »
I hope this basic diagram will help somebody.
Basic accessories and relay.jpg (38.25 KiB) Viewed 2287 times
HarveyCamm
Has thanked: 76 times
Been thanked: 123 times
Post by HarveyCamm »
I fitted one of these
Dual USB Socket Charger,...
There's a switch on the outlet box but it doesn't isolate the kit from the battery supply so +1 for the commemts on switched supply
Harv
chunky butt
Has thanked: 54 times
Been thanked: 699 times
Post by chunky butt »
Dave what ever you do put an inline fuse in, and waterproof switch so it won't overload, and you can isolate it ;)
Cornishman
Has thanked: 65 times
Been thanked: 102 times
Post by Cornishman »
chunky butt wrote: Fri Nov 26, 2021 8:11 pm Dave what ever you do put an inline fuse in, and waterproof switch so it won't overload, and you can isolate it ;)
If it’s for his Beta there’s waterproof and waterproof. It might be safer buying something through a yacht chandler.
https://www.force4.co.uk/item/Osculati/ ... Socket/9JK
