Hondas and Suzuki motors. Thoughts?
SteveR
Has thanked: 233 times
Been thanked: 83 times
Post by SteveR »
I have been meaning to post this for an age but never got around to it...
I have had several V twin Honda's over the years as well as a single XR400. All used to tell me when the engine oil needed changing, as the gearbox will start to get slighty notchy in changes. The Old A/C Suzuki's behaved in a similiar manner. I also saw it in a 400cc suzuki quad!
Drop the oil out, even if the mileage was not requiring it, and an instant transformation. My guess is it is the wet clutch that is the factor, but not sure... . Always use decent oils, and filters.
Is this behaviour seen in other bikes?
Has thanked: 1414 times
Been thanked: 1669 times
Re: Hondas and Suzuki motors. Thoughts?
Yes...and it's even true in trucks...with dry clutches.
SteveR
Post by SteveR »
Richard Simpson Mark II wrote: Sun Nov 21, 2021 6:37 pm Yes...and it's even true in trucks...with dry clutches.
Fresh oil acting as a cushion on the teeth in the cogs?
I have asked the reason...of both gearbox manufacturers and oil cos.
There was no single simple explanation...but one suggestion was that oil wore out. Not talking contamination, more the long and complex hydrocarbon molecules that determine the viscosity and other properties of the oil being 'sheered' into smaller molecules. Like chopping the legs off a spider. So yes, the 'cushioning' effect would be diminished, and maybe make the syncho rings more baulky.
SteveR
Post by SteveR »
Richard Simpson Mark II wrote: Sun Nov 21, 2021 8:41 pm I have asked the reason...of both gearbox manufacturers and oil cos.
Makes very good sense to me.
Drop the oil out of the wee Honda, and the oil at 2K miles is thin, smells "odd" and obviously is worn out, as evidenced by the improvement of a operation from a couple of litres of fresh lube...
