E10 Fuels
- Has thanked: 1414 times
- Been thanked: 1669 times
- Has thanked: 95 times
- Been thanked: 448 times
Re: E10 Fuels
you couldn't make it up--just seen this also (more unobtanium from Boris the Bogladite) "The UK government department overseeing the phasing out of diesel cars still relies on them for its own fleet.
Figures obtained by the BBC show the Department for Transport operates 1,234 cars - 672 run on diesel, 63 on petrol, with the rest electric or hybrid."
- Has thanked: 1177 times
- Been thanked: 727 times
Re: E10 Fuels
Looks like they are phasing them out then?catcitrus wrote: ↑Sat Sep 18, 2021 11:07 am you couldn't make it up--just seen this also (more unobtanium from Boris the Bogladite) "The UK government department overseeing the phasing out of diesel cars still relies on them for its own fleet.
Suzuki DR200 Djebel.
Re: E10 Fuels
Popped in to my local bike shop to pick up a new inner tube and was amazed as to how many two stroke engine failures and problems have occurred following the use of E10. I wonder if because of the slow burn time characteristic it is consuming the two stroke oil
- Has thanked: 65 times
- Been thanked: 102 times
Re: E10 Fuels
Amazing seeing how short a time it has been on sale in the U.K.Hugh wrote: ↑Wed Oct 13, 2021 9:12 pm Greetings,
Re: E10 Fuels
Can’t be that Hugh, once the fuel/air/oil mix has reached the combustion chamber it has already performed its lubrication function and you actually want it to be burnedHugh wrote: ↑Wed Oct 13, 2021 9:12 pm Greetings,
Re: E10 Fuels
According to this Chinese study E10 is actually very good for two-strokes
https://www.researchgate.net/publicatio ... oke_Engine
But anecdotal evidence suggests that ethanol causes loads of problems, especially in engines that are not in regular use.
My chainsaws etc are difficult to start unless I put Ethanol Shield into the fuel. I don't know how it does it, but it does make them easier to start.
It's also responsible for buggering-up an endless number of fuel tanks.
Re: E10 Fuels
I know facts and experience are boring compared to conspiracy theories but I have been using E10 in 2stroke chainsaws and strimmers for a decade. No starting problems, no meted plastics. The U.K. is way behind the EU in the use of this fuel any problems have been well documented. If you really believe that your engine/fuel tank/pipes might be in danger it’s simple, ask the manufacturer. Don’t listen to the doom merchants.
Re: E10 Fuels
The manufacturers of my garden machines give explicit instruction not to leave even E5 fuel in the machines, and warns that doing so will invalidate the warranty. The dealer who sells them says it's a very serious issue.
Re: E10 Fuels
Our local supermarket filling station is closed while they convert it to E10. New hoses, pumps, seals etc required. A major job, by all accounts.Cornishman wrote: ↑Wed Oct 13, 2021 9:32 pmAmazing seeing how short a time it has been on sale in the U.K.Hugh wrote: ↑Wed Oct 13, 2021 9:12 pm Greetings,
