Lithium more reliable than Lead?
- Has thanked: 1187 times
- Been thanked: 761 times
mate of mine needs a new battery for his DRZ, he is under the impression that modern conventional batteries even the historically considered quality brands offer poor quality I share that opinion as does a local guy in the trade. He is considering a Lithium replacement anyone with history on this conversion with any thoughts?
- Paul_C
- Has thanked: 1011 times
- Been thanked: 1146 times
Re: Lithium more reliable than Lead?
You need to consider that most Lithium batteries don't take favourably to being charged at over 14 volts. Most rectifier/regulators and chargers work at around 14.5v. So you may need a new rec/reg and maybe a charger too.
Just along for the ride.
Weight saving is not the aim but obviously an advantage He has a number of vehicles and some are little used so cumlative battery replacements are a pain, so little use long term reliability is the main target, buying a new charger would probably be acceptable, YUASA VARTA EXIDE etc dont seem to give the reliability they once did over budget batteries, seems a common theme, a local bike guy in the electric component supply game won't sell batteries anymore as the customer return/satisfaction rate is so bad, he has stated many new ones arrive with him already below optimum ( got a basic knowledge of volts and amps but little more myself) so myself and my mate looking at a different direction. I have read that these batteries have idiosyncrasies and need to be managed a bit, not heard the one about charging voltage though will keep it in mind. Thanks for the info so far anyone run one for a number of years? Recommended Brand's? Charger's?
- Has thanked: 169 times
- Been thanked: 68 times
I had a Lithium battery on my KTM exc it was less than three years old and failed completely without warning, I have replaced it with a lead acid battery
- Has thanked: 419 times
- Been thanked: 158 times
- Has thanked: 1414 times
- Been thanked: 1669 times
https://www.demon-tweeks.com/uk/brand/odyssey/
are very good. Not a direct like-for-like replacement as they are small.
They use thin-plate lead and are very powerful. Last for years.
- Snaf MKII
- Has thanked: 920 times
- Been thanked: 752 times
Nothing to do with sea/river you stopped in then and had to be towed home
