CB125F 2017 tickover issues
Has thanked: 807 times
Been thanked: 1062 times
Re: CB125F 2017 tickover issues
Post by Richard Simpson Mark II » Wed Dec 16, 2020 7:49 pm
Sounds like it's leaning the mix too much when warm.
Either it thinks it's hotter than it is, or is sucking in air downstream of the injector.
Hoggyf
Has thanked: 52 times
Been thanked: 39 times
Post by Hoggyf » Wed Dec 16, 2020 8:13 pm
Can I try just disconnecting the air sensor in the air Box? Any way of testing the sensor?
Then:
Now:
Snaf MKII
Has thanked: 596 times
Been thanked: 486 times
Post by Snaf MKII » Thu Dec 17, 2020 8:42 am
There will be a temperature sensor somewhere, probably on the radiator. If it's faulty it can fool the ecu in to thinking its to hot or to cold and either under/over fuel it. Simple to test if it makes any difference and cheap to change if you think it's suspect or test for resistance change if you can find data on it.
Do you know what the sensor in the airbox is? Looking at parts diagrams I can't see one and the air temp sensor is on the throttle body.
Hoggyf
Post by Hoggyf » Thu Dec 17, 2020 5:57 pm
Definitely no sensor on the radiator, coz there isn't a radiator :mrgreen:
Dunno what the air box sensor is, I was assuming it was air temp??? What's the sensor you saw on the throttle body?
Then:
Now:
Snaf MKII
Post by Snaf MKII » Thu Dec 17, 2020 6:28 pm
Uh yeh, trick question :-). Try the rear of the cylinder head there's one there.
Hoggyf
Post by Hoggyf » Fri Dec 18, 2020 4:40 pm
After further digging, no air leaks having sprayed all over the throttle body and air box etc, fiddle with the throttle cable and adjusted it slightly to tighten it and open the throttle very slightly and sat and ticked over quite merrily for about 15 mins blipping the throttle etc and would always drop back to around 1300 revs nicely. Turned it off and started it again and it wouldn't tick over at all, just die :oops:
Been digging through parts lists and found that there is an air temp sensor in the air box, and an oil temp sensor on the head, plus oxygen sensor in the exhaust port, there's also a bank angle sensor somewhere but can't find that nay where, on the 4rt trials bikes the bank sensor is a common issue and you usually link it out to stop it being a problem so need to find that.
Still can't find the tps, I'm assuming it's below the solenoid on the throttle body, but what's the solenoid on the throttle body for?? Shutting fuel flow off? Can't think of a reason why there is one tbh.
Then:
Now:
Post by Richard Simpson Mark II » Fri Dec 18, 2020 5:22 pm
Jeeez....I feel old just reading that!
Hugh
Has thanked: 558 times
Been thanked: 669 times
Post by Hugh » Fri Dec 18, 2020 9:36 pm
Greetings again,
Here is another link, similar to the one found earlier by Bill;
https://bikesandtravels.com/biker.aspx?ride=750
Thedktor
Has thanked: 124 times
Been thanked: 137 times
Post by Thedktor » Sat Dec 19, 2020 7:51 am
Sorry missed your PM.
As has been mentioned the ECU will adjust the mixture depending on the air and engine temperature, so assuming you have no air leaks it is quite likely one of these is faulty - a diagnostic computer will show straightaway if these are incorrect.
Has this been done?
- Steve
Southampton area
DR350, 349, DRZ, 701
Hoggyf
Post by Hoggyf » Sat Dec 19, 2020 11:07 am
Greetings again,
Unfortunately thats a CBF125 and not the CB125F - different bikes, there's loads of info on the CBF but not much on the CB125F sadly but cheers anyway
Has this been done?
no hasn't been on the computer as my local bike shop doesn't have the ability to connect to this?? so means going to a main dealer and as she's selling it we were trying to keep the cost down but looks like it might be the best way as we're both loathe to sell a bike with a known fault and selling it with an advised fault will drop the price massively.
Then:
Now:
Users browsing this forum: No registered users and 101 guests
