Okay I've been busy adding yss pd valves to the xt660z and we'll I need x2 alloy spacers to go on top of damper rod and the yss valve..
Outer diameter is 36mm inner diameter 30mm so would think 4 to 5 mm thickness
The height of each circular ring spacer is 10mm..
https://www.squaredeals-ltd.co.uk/yss-p ... 1770-p.asp
Something like in the link above... So any engineers on here?... Pm me a price for say 5 sets so as to make it worth while.. Etc..
Could be 35mm outer diameter as I can find alloy tubing but have no chop saw lol...
Cheers..
This is the top of the xt660z damper valve
Alloy spacers required making please..
- soho
- Has thanked: 105 times
- Been thanked: 277 times
Re: Alloy spacers required making please..
I've got a very nice Myford Super 7 lathe you are free to use Russ if you know how to operate one ? I'm still struggling with the handbook.
Last time I used a lathe was at school well a milling machine and buggered that right up... Thanks for the offer...
How about using a hub ball bearing? You could try my local friendly bearing specialist;
https://www.emmett-enterprises.com/inde ... page=index
Another contact might be Moorside Manufacturing at Haughton Green; 0161 335 0235
Users browsing this forum: No registered users and 98 guests
