Clutch help
bill_qaz
Has thanked: 503 times
Been thanked: 735 times
Re: Clutch help
Post by bill_qaz » Mon Jul 13, 2020 5:24 pm
Clutch holder
Hugh
Has thanked: 558 times
Been thanked: 669 times
Re: Clutch help
Post by Hugh » Mon Jul 13, 2020 8:31 pm
I have just used the old 1p :lol: trick on the Pampera. Take care not to over tighten the clutch clamping bolts, they are prone to snap in the clutch basket fingers. When securing them tighten a little and often alternating diagonal pattern.
It is possible to buy a pattern product of the Honda factory clutch tools and for what they cost they could be an investment to you, as an example;
https://www.motorcycleproducts.co.uk/mo ... ls/3/34354
Ps my penny, apologies 'Mam.
Thedktor
Has thanked: 124 times
Been thanked: 137 times
Re: Clutch help
Post by Thedktor » Tue Jul 14, 2020 6:22 am
In my experience a significant amount of clutch issues are caused by the cable. Anything apart from a fresh OEM cable will not work properly, the usual problem of not being able to select neutral easily as the clutch is not releasing correctly. And/or less than smooth operation.
Not sure if this is the fault cause here, but always consider the cable if grabbing your clutch does not result in the satisfaction you hope for! :shock:
:P
- Steve
Southampton area
DR350, 349, DRZ, 701
Snaf MKII
Has thanked: 589 times
Been thanked: 483 times
Re: Clutch help
Post by Snaf MKII » Tue Jul 14, 2020 7:08 am
The trialists use a clutch lightner on thier TLR Hondas which have the same base engine and clutch mechanism.
https://www.ebay.co.uk/itm/HONDA-tlr200 ... 0877802951
Brenhden
Has thanked: 919 times
Been thanked: 604 times
Re: Clutch help
Post by Brenhden » Tue Jul 14, 2020 9:46 am
Thedktor wrote: ↑
:P
Will swap out the cable, at least thats easy and cheap, this bike has the easiest to find neutral I've ever owned.
Snaf MKII wrote: ↑
Cool widget, but the clutch is light.
Honda XR125.
Brenhden
Re: Clutch help
Post by Brenhden » Tue Jul 14, 2020 9:47 am
Hugh wrote: ↑
I have one of those, there is no way to get in there without it :)
Honda XR125.
bill_qaz
Re: Clutch help
Post by bill_qaz » Tue Jul 14, 2020 12:11 pm
Brendan does it have a judder spring and washer and are they fitted correctly?
Petethefeet
Been thanked: 5 times
Re: Clutch help
Post by Petethefeet » Tue Jul 14, 2020 1:16 pm
I was convinced the clutch on the XT was on the way out last year, looked at clutch kits etc.
Took the cable off at both ends and when you pulled the cable inner through it was like it was lubricated with treacle, would move freely but very damped, think it was were it ran past the exhaust and the oil had dried out and got thicker over the years.
I new cable sorted it, different world.
Hope it helps
Pete
XT350 1988
Triumph Thunderbird 1957
Brenhden
Re: Clutch help
Post by Brenhden » Tue Jul 14, 2020 2:23 pm
bill_qaz wrote: ↑
Brendan does it have a judder spring and washer and are they fitted correctly? 20200714_121019.jpg
Here is my one, annoyingly back first...
Honda XR125.
bill_qaz
Re: Clutch help
Post by bill_qaz » Tue Jul 14, 2020 3:36 pm
Looks like the 125 doesn't use them then?
Return to β€œTECHNICAL”
Users browsing this forum: No registered users and 87 guests
