I wonder what that wire was supposed to do?
Could be a Lambda sensor input or similar.
My tdm running bad.
- Been thanked: 99 times
Re: My tdm running bad.
I had a tdm850 great bike , you mite want to check the timing chain + tensioner high milers can give bother. Difficult to start, the engines are basically bullet proof as long as you change oil regularly, be careful when changing oil due to dry sump.
I wonder if you have sorted out the problem/s with your bike yet and if so what was/were the causes?
All such info adds to the knowledge base for others in a similar predicament.
