Tiger 900 exhaust
Den TeeDiem
Tiger 900 exhaust
Post by Den TeeDiem »
Hi, I'm lookimg at maybe getting a Tiger 855, 885 or 955, depending on what comes along at the right price.
Whilst looking around I've noticed some of these bikes have a twin exhaust while most are single sided, can anyone tell.me which model/years are which?
Many thanks in advance,
Dennis
lancashirelad
Has thanked: 201 times
Been thanked: 272 times
Re: Tiger 900 exhaust
Post by lancashirelad »
The first Tigers the 885 referred to as "steamers" for some reason had twin exhausts the later 885i & 955i had single exhausts, I think?
I never had the early model only a 885i & 955i, then a Tiger 800 all good bikes but I would go for an 800 if budget allows the first models were very top heavy.
Toe
Has thanked: 25 times
Been thanked: 72 times
Post by Toe »
Twin exhaust Tigers are the 885 carbd bikes. Anything after is EFI and single exhaust.
KHM IDN LAO MMR PHL THA VNM
fraserdog
Been thanked: 3 times
Post by fraserdog »
Tome wrote: Thu Dec 21, 2017 1:29 pm Twin exhaust Tigers are the 885 carbd bikes. Anything after is EFI and single exhaust.
+1 on that.
threepot
Has thanked: 9 times
Been thanked: 32 times
Post by threepot »
Apparently the name 'steamer',originated in America,when owners of the newer injected Tigers reckon ed that the older carbed model was like a 'steamboat' compared? I've had mine about 6yrs,and it's been a great bike. Nothing much gone wrong,their pretty 'bulletproof'. But they need to be used regularly. Carbs don't like stale fuel,and batteries need to be in good shape. Coils WILL fail eventually,but you can now buy fresh set for about £100,or put Denso stick coils in.
Prices range from about £900_2400,depending on condition?
Best place for info is
www.tigertriple.com
threepot
Post by threepot »
threepot
Post by threepot »
threepot wrote: Fri Dec 22, 2017 3:45 pm
threepot wrote: Fri Dec 22, 2017 3:42 pm Apparently the name 'steamer',originated in America,when owners of the newer injected Tigers reckon ed that the older carbed model was like a 'steamboat' compared? I've had mine about 6yrs,and it's been a great bike. Nothing much gone wrong,their pretty 'bulletproof',and their built like Tiger 'tanks'! They handle surprisingly well,and the 'triple engine has bags of character. Front brakes are shite tho. But they need to be used regularly. Carbs don't like stale fuel,and batteries need to be in good shape. Coils WILL fail eventually,but you can now buy fresh set for about £100,or put Denso stick coils in.
www.tigertriple.com
Den TeeDiem
Thanks everyone, that clears things up a bit.
The one I'm looking at is a 2000 885i.
I ride a '92 TDM at the mo, they're quite top heavy too, the Tiger tank appears a little lower than the TDM and wider, so should feel less top heavy than if you came from a different bike.
lancashirelad
I had a '99 885i great bike plenty of pull with it!
threepot
Post by threepot »
You might be better off with the 955i? Get some feedback on the www.tigertriple.com forum
