I'm after a new set of forks for my 2003 DRZ400e...corrosion has been busy under the rubber shrouds.
There's quite a few 400s forks on eBay are they the same?
Are there other forks that will do the job (better)?
Does anyone have a set of suitable forks for sale?
DRZ 400e Forks
Re: DRZ 400e Forks
Might be best have new seals,bushes and re chromed as you then know it's all good. Used parts on eBay might be just as bad as what you have
Re: DRZ 400e Forks
never seen that before either! S & E forks are the same from 2002 onwards. cheers
2016 Beta 300rr- In the 2 stroke come-back club!
- Has thanked: 100 times
- Been thanked: 523 times
Re: DRZ 400e Forks
Lack of cleaning and maintenance :whistle:
:laugh:
:laugh:
Re: DRZ 400e Forks
Mine has the same kind of corrosion less extensive so I cleaned off all the loose stuff then used a twopack metal mix and smoothed it out then wrapped it in carbon fibre look a like wrap. Did it a year ago and all is well.
Mine was right at the bottom of the folk rather than where yours is but hey you may surprise yourself.
Mike
Mike
Re: DRZ 400e Forks
Hi , I bought a set of drz e forks to replace a set which came off my e , they had similar wear marks but not so bad , I also have a set of s forks , one stanchion has a scrape , if your near me your welcome to check them out if suitable you could have the lot for say 30 quid ? You may be able to mix and match ? The e seals etc were ok The s I bought from a breaker so can't vouch for them
- Has thanked: 201 times
- Been thanked: 272 times
Re: DRZ 400e Forks
I have a pair for sale off a CCM SR-40 not sure if they are similar to the Suzuki ones though?
