I've got a small issue with my 1150RT.
When starting form cold all is well but about 30 seconds later there is a loud ish ticking from the right hand pot. It goes when the engine is hot.
Do we think a tappet adjustment is in order or could it be anything else?
Mike
R1150RT ticking
R1150RT ticking
Re: R1150RT ticking
Now if it was a 1200GS I might agree with you and i'm pretty sure it wasn't built buy an Islamic convert!!!
Mike
Mike
- Has thanked: 396 times
- Been thanked: 617 times
Re: R1150RT ticking
Could it be the throttle body? If it is the same set up as the 11gs put your finger on the spool that controls the throttle cable beside the throttle body and put a wee bit of pressure on it. If the ticking stops, then it is the throttle body.
Re: R1150RT ticking
I've checked that and it 100% coming from inside the head...i'll pop off the cover later and see what I can see.
Mike
Mike
R1150RT ticking
It's going blow up
Sent from my SM-G900F using Tapatalk
Re: R1150RT ticking
from cold - end play on the rocker shaft?
http://www.worldtour.org.uk
Re: R1150RT ticking
Is that easy to fix?
Mike
Mike
Re: R1150RT ticking
Cut the red wire
Followed by blue then green. Remove to safe distance. And dispose of in responsible manner. :whistle: (thumbs)
Re: R1150RT ticking
I'd check the exhaust manifold for leaks/cracks. They can tick on start up and close once they expand with heat. (thumbs)
