GS Adventure Exhaust Valve / Flap
MarkN
Post by MarkN » Sun Feb 07, 2016 2:55 pm
My dealer has told me that the exhaust valve thing inline on the pipe is no longer working on my bike and typically, it isn't covered on the extended warranty. They want about £350 for a new one.
Anyway, I've been told that it can be taken away by replacing the bit of pipe with a short section.
Has anyone had it done on their bike? Where can I get hold of the pipe?
Thanks for any help.
Mark
dmac
Re: GS Adventure Exhaust Valve / Flap
Post by dmac » Sun Feb 07, 2016 3:11 pm
Mark suggest you post on UKGSER, wealth of knowledge on there!
Currently an F650GS, DR350 and RV125 in the family stable.
Tonibe63
Has thanked: 773 times
Been thanked: 462 times
Post by Tonibe63 » Sun Feb 07, 2016 3:16 pm
Do a search on UKGSer
Here is a recent thread http://ukgser.com/forums/showthread.php ... st-flapper
AustinW
Has thanked: 4 times
Been thanked: 16 times
Post by AustinW » Sun Feb 07, 2016 3:58 pm
I replaced my flappy thing about 6months ago. There's no difference in day to day use. Nippy Normans and I think motoworks sell the link pipe for about £30. But if you look on UKGSer there's a sticky somewhere on replacing the valve giving the dimensions of the link pipe needed and a step by step guide. The pipe should About £10-£15 from an exhaust maker. I got mine from NN as the exhaust guy local to me starting dicking about.
Simple job but get some penetrating oil on the two clamps for a day or two beforehand to make sure they will come off. IIRC the clamp and bolts are stainless but the nuts aren't (or was it the bolts? Whatever there is a risk something will be seized or difficult to remove). Once that's done it really is easy.
JonnyBravo
Been thanked: 8 times
Post by JonnyBravo » Sun Feb 07, 2016 4:20 pm
Exactly what he said above - (thumbs)
i bought my bit of pipe from Nippy Norm -
£30 is a lot for a bit of pipe but it also saved a lot of time sourcing something local
MarkN
Post by MarkN » Sun Feb 07, 2016 6:51 pm
Thanks for the link, that's interesting reading. (thumbs)
MarkN
Post by MarkN » Sun Feb 07, 2016 6:54 pm
AustinW wrote:I replaced my flappy thing about 6months ago. There's no difference in day to day use. Nippy Normans and I think motoworks sell the link pipe for about £30. But if you look on UKGSer there's a sticky somewhere on replacing the valve giving the dimensions of the link pipe needed and a step by step guide. The pipe should About £10-£15 from an exhaust maker. I got mine from NN as the exhaust guy local to me starting dicking about.
Thanks Austin, just seen the link to NN, I'm going to order the part tonight and do the work this week. Good tip about the nuts too, when I get home from work tomorrow night, I'll give them a good spray and coating. (thumbs)
bimota
Been thanked: 5 times
Post by bimota » Sun Feb 07, 2016 7:46 pm
mine stopped working on my 2010 gsa, told when in for service but it had seized in the open position.
SO did nothing just kept riding because i didn,t know it was seized and bike rode with no issues.
rob
Rederic
Has thanked: 44 times
Been thanked: 154 times
Post by Rederic » Sun Feb 07, 2016 8:17 pm
I would just get a set of decat headers for it, and enjoy the extra bit of umph you get and better fuel consumption (thumbs)
misterlaffer
Post by misterlaffer » Sun Feb 07, 2016 8:37 pm
Sounds like you have made the choice to swap it out with the blank pipe, however they can be cleaned easily. Mine was playing up early last summer just before a big trip to Spain. Kept making a squeaking noise as it pivots. My dealer wanted about the same as yours to replace. They tend to seize in the open position so usually cause no problem. However, I took the end can off and took the butterfly right off sure enough it was really stiff. I cleaned it in a combination of Mr Muscle and left it to soak in petrol overnight. This freed it up, as you would imagine tons of carbon came out. My trip was saved, and caused me no issue since.
The reason the dealer was alerted to this is if the solenoid struggles too much on resistance it throws up an error code, they naturally assume it needs changing, so in your position I would always try and clean first. I have an electronic copy of refit and adjust instructions for the Bowden cables , PM me and I will send you a copy if you decide to try and clean first.
Failing that as mentioned by others,Nippy Normans sell a slip on blank pipe to replace it with that comes with instructions on how to remove the motor and cables etc. However, when I last looked at this they wanted £30 or more for what is essentially a bit of standard pipe I think you can get cheaper from a regular car exhaust place they use for similar reasons. That would be my next option if it fails again and I can't free in future.
Users browsing this forum: Bing [Bot] and 149 guests
