Bought myself a mini sports cam to attach to the bike from E-Bay
[ebay]351149005042[/ebay]
Added to this a
SanDisk 32GB Ultra Micro SD (SDHC) Card Class 10 UHS
All moving pictures are blurred so does anyone know if I have done something wrong or is the camera just a pice of c@@p
Video question
- Been thanked: 1 time
Re: Video question
Does it have an adjustable focus? Sometimes the lense at the front can be adjusted.
Current bikes...
Re: Video question
No it does not. When stopped the camera will focus on objects at different distances.
I will post some video tomorrow. Scrubbed what I had when formating the card again.
Re: Video question
just a thought it hasn't got a clear lense protector on it
Re: Video question
I would say that it's the FPS speed not being able to coupe with the constant re-focusing, and the lack of anti vibration software.
Midland XTC range are not bad, if you don't want to pay Go Pro or Drift prices, or the lidl HD for £50 that comes up every now and then. (thumbs)
Re: Video question
Good call never thought of that
No
No cling film over lense. Took the clear lense cover off that makes it water proof and no diference to the film quality. (just uploading a bit of film to photobucket.)
No
Re: Video question
I can't see the picture of your camera on this iPad for some reason :unsure:
I've an old bullet cam that worked fine and then suddenly went off focus on a trip. It wasn't meant to be adjustable focus, but after peeling a sticker off I found that the lens cover unscrewed and the lens itself was on a thread. I readjusted it using the garden fence to focus on (dvr has a screen on it) and used a dab of tippex to lock it in place before replacing the lens cover.
It was off focus completely though so maybe that's not what you're experiencing?
Re: Video question
You could try reformatting the SD card. :woohoo: Have you tried doing it on your computer? My Drift use to have a freezing/Laggy problem even with a good SD card. I just simply plug the camera in my computer and use it as an external hard drive. I would imagine you can still do that for most cameras these days. You can view the data stored on the SD card while its still slotted inside the camera.
If your using Windows, Go to MY COMPUTER and you should see the camera being recognised as a drive. Right click and select formate (Make sure theres nothing on the SD card you don't want to lose hmy: )
Hope this helps, it has certainly worked for me (thumbs)
Re: Video question
Stewie
I was leaning towards (though not in such technical terms) your sugestion. Untill
I uploaded a short film to Photobucket. when I viewed the film on line the picture was clear (not perfect but 95% clearer)the lag seams to have disapeared. Downloaded the film to my hard drive but it was still as bad as before the upload. So now thinking it might be my viewing software that is to fault.
Fordy
Havent posted film yet for the reasons above. Good tip about the tipiex will keep that in mind.
Andy
Need to get a card reader as I have been doing everything with the card in the camera and teatherd to the USB port including reformating twice.
Fordy
Andy
Re: Video question
Are you sure your PC is up to the job? My films on my gopro have to be edited and played on my iPad as my PC can't cope.
Current bikes...
