The bike has just come back from a 6000mile service and the last couple of times i have had problems with tick over. The bike starts fine and the stalls straight away. I can keep the revs up fine and it doesnt stall. Then at a set of lights it stalls. After a while the problem goes away and it doesnt do it everytime it starts. Any ideas?
Si
the start of another problem
Oh, Edmund, can it be true, that I hold here in my mortal hand a nugget of purest green?
2013 Triumph tiger 800 xc
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
https://www.youtube.com/user/kentbyways
http://www.kent-byways.co.uk/
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
Re: the start of another problem
Yes waiting for replies.
si
si
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
did you try adjusting the idle speed adjuster on the carbs a small bit
That I've got to see! (thumbs)bull wrote:did you try adjusting the idle speed adjuster on the carbs a small bit
Has the bike given any error messages yet? Low speed problems are often the lambda sensor acting up which can be caused by something as simple as filling up with cheaper fuel then normal.
News from the tiger 800 forum is that it could be a dirty stepper motor. So sprayed a load of damp start/cleaner in there and see how it goes.
si
si
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
1998 Honda XR 250L
2003 CCM 404 DS
2005 MGTF
AndyB wrote:That I've got to see! (thumbs)bull wrote:did you try adjusting the idle speed adjuster on the carbs a small bit
did I miss something
Its fuel injection B)bull wrote:AndyB wrote:That I've got to see! (thumbs)bull wrote:did you try adjusting the idle speed adjuster on the carbs a small bit
Si you need to dismantle it to clean it, you cant just spray stuff through the gap and hope mate.
Mike54 wrote:Its fuel injection B)bull wrote:AndyB wrote:That I've got to see! (thumbs)bull wrote:did you try adjusting the idle speed adjuster on the carbs a small bit
my mistake (thumbs)
sexysi wrote:The bike has just come back from a 6000mile service and the last couple of times i have had problems with tick over. The bike starts fine and the stalls straight away. I can keep the revs up fine and it doesnt stall. Then at a set of lights it stalls. After a while the problem goes away and it doesnt do it everytime it starts. Any ideas?
Si
it might be a problem with the throttle, or something simple like that
