On checking the chain on my Ten I found a few of the O rings gone or hanging out broken.
Done 6K kept clean and lubed (Tutoro) adjusted and a KTM chain guide fitted sprockets in very good condition. Any idea what could cause this. Would you recommend a new C&S kit?
Drive chain problem help please
Re: Drive chain problem help please
The only things that could have casued that are either a bad chain....where did you get it..don't say ebay please?
Or not enough lube and too much heat/friction.
Or damage from a cleaning product..what do you use?
Mike
Mike
Hi Mike, It's the standard chain that came with bike from new, always well lubed, I clean it with gear oil let it soak into any grime then wipe off. Did give the bike a good hammering last weekend off road maybe the chain didn't like itMike101 wrote:The only things that could have casued that are either a bad chain....where did you get it..don't say ebay please?
Mike
- Has thanked: 570 times
- Been thanked: 894 times
ill guess thats its a regina chain ..if so dont worry its a crap chain ..
i like ek mvxs chain ..its pretty tough
suppier below
https://www.bctmotorcycles.co.uk/index.jsp
suppier below
- Has thanked: 1 time
If its only on a couple of "o rings"I wouldn't worry too much,as we all know they are there to seal in lubricant,they also make the drive of the chain a tad quieter,just keep it well lubed,how worn are the sprockets btw?,id also use a spray lube unless you already doBanzai wrote:On checking the chain on my Ten I found a few of the O rings gone, Any idea what could cause this. Would you recommend a new C&S kit?
I'd second this. Keep it lubed & run it.chairhead64 wrote:If its only on a couple of "o rings"I wouldn't worry too much,as we all know they are there to seal in lubricant,they also make the drive of the chain a tad quieter,just keep it well lubed,how worn are the sprockets btw?,id also use a spray lube unless you already doBanzai wrote:On checking the chain on my Ten I found a few of the O rings gone, Any idea what could cause this. Would you recommend a new C&S kit?
Lightness is everything.
I once had this happen after fitting the gearbox sprocket back to front, unlikely you have done this but may be worth checking back wheel alignment as being out would cause a similar problem, chain tensioners/wheel spacers etc!
Isn't your bike a few years old Banzai ?
If it is the standard C&S then the rubber could have become brittle with age, no garrantee the chain was kept lubed before you got it.
As others have said, run it 'til you need new sprockets.
Nice to see you enjoying it
Rick
Rick
This happened to my XTR a few months ago. Where the O rings were damaged was also where the links were stiff or frozen. Wthin a few hundred miles the chain was a right mess of frozen links, missing O rings, and tight spots so bad that even backed right off I couldn't get the chain slack enough - the frozen links put loads of little kinks in the chain that took up the slack. Similar mileage to you as well.
New C&S is the only cure.
Sent from my iPhone with a smile
- Been thanked: 1 time
Whatever you use as chain lube may be rotting the links.
Why is the chain all black?
Has it been run too tight and overheated?
