Maps from garmin to Basecamp.
EarthWorm
Post by EarthWorm »
Anyone know if it is possible to transfer the map from a garmin montana onto a PC so it shows in Basecamp without having to connect the GPS unit every time?
Fear is the little-death that brings total obliteration
Oop North John
Has thanked: 154 times
Been thanked: 199 times
Re: Maps from garmin to Basecamp.
Post by Oop North John »
What sort of map, is it on an SD card?
I cloned an SD card map of Morocco using this idea onto a SD card that lived in the computers flash drive slot:
http://www.gpsrchive.com/Montana/Clone% ... FlashDrive
EarthWorm
Post by EarthWorm »
Thanks john that looks like one way to do it, yea the map is on an SD card, I'll give it try :arrow: :arrow:
Has thanked: 330 times
Been thanked: 646 times
Post by Tramp »
if the garmin map is unlocked just copy and paste to a new card..make sure the garmin file is inserted into a garmin folder otherwise it cant be read by basecamp..img etc...
or just download a opensource topo map to the basecamp maps folder on pc :D
EarthWorm
Post by EarthWorm »
cHEERS rUSS, i'LL TAKE A LOOK AT THE openmaps stuff
Oop North John
The opensource maps are good value, but, in the past the mapping hasn't been as accurate as the paid for stuff, eg, a road junction shaped like a "T" has a gap between the two roads, so the laptop / GPS sees it as a no through road if your going up to the "T" junction and so routes you around a scenic route to go past the junction.
