How "NOT" to Husky
Dutchgit
Has thanked: 40 times
Been thanked: 5 times
Re: How "NOT" to Husky
Post by Dutchgit »
It's a steep learning curve but you're doing well at it ! (thumbs)
HU55KY
Post by HU55KY »
The bag of goodies arrived from Huskysport today and the new carb hoses.
The flywheel has been transferred from the old motor to the new.
The rear swingarm has a nut on the end of the axle bolt... there's a novelty :whistle:
The tank can now hang on two hangers rather than just the one.
New pads in the front caliper and the caliper bolted back on... does seem to be binding a bit :blush:
And the rear subframe and air box have had a clean and been refitted.
I've ordered a short piece of silicone hose that has an internal diameter of 60mm to hopefully solve the carb manifold conundrum, I'll know more when it arrives.
HU55KY
Post by HU55KY »
To get the flywheel nut torqued correctly I had to take the transmission cover off and wedge a soft washer in the teeth of the primary gears and then I had to download the user instructions for the torque wrench... ;)
Flywheel on, then the flywheel cover and the transmission cover... so far so good.
Now to the clutch cover which wouldn't fit :blink: so I pulled the rod out of the middle and it's about 5mm longer than the one from the old engine :dry:
What to do...
Dutchgit
Post by Dutchgit »
But the clutch cover is on the engine in the pic you first showed the new engine.
Surely there must be some mistake ?
Or is the operating cylinder not going on ?
HU55KY
Post by HU55KY »
You're quite right!
The small operating cylinder, the cover on the end of the braided clutch hose.
This one...
Dutchgit
Post by Dutchgit »
Try taking the cover off the master cylinder, maybe too much oil in there.
You have to push it on a bit but make sure you do it straight. (you can use the bolts doing it but you'd have no feel doing it that way.)
HU55KY
Post by HU55KY »
Thanks for your input Dutchgit.
I've sent an email to Huskyparts and I'll phone Huskysport in the morning before I get heavy handed.
Dutchgit
Post by Dutchgit »
Don't forget the gasket !
HU55KY
Post by HU55KY »
Having been a bit dim I have now seen the light...
It dawned on me that a clutch actuator hose being braided was a dead giveaway for "quite a bit of pressure needed" to push that rod through it's little hole and no amount of pushing it with my thumb was going to make the slightest difference... :blush:
I also noted that each rod in it's respective engine stuck out by the same amount.
As you said Dutchgit, I reassembled the cover and the piston, not forgetting the little rubber o-ring, and bolted it back on, job done. (thumbs)
The decompressor cable has been hooked up, the rear brake pedal and cylinder connected, the kick start... ooh temptation :evil:, new radiator hoses on, new chain rollers as the old ones had completely seized just like the chain guide which I still need to replace, and finally the oil filters removed cleaned, last remaining dribbles of old oil out and the paper oil filter removed ready for a new one!
I haven't looked at the new chain yet but imagine I'll have to split it to get the correct length?! Can anyone recommend a good chain tool???
Dutchgit
Post by Dutchgit »
Fill the oil filter with oil before you fit it or it might expand, making it more difficult to get next time.
If you use a grinder to grind off the little stub ends you can use a small punch to separate the chain. Easiest is to use a separable link if you don't want to invest in tools. (Carry a spare link on the bike)
Return to “HOW TO..........”
